1985 20hp Johnson moldy interior
bgianpetro
Hi all,
Hopefully my first question on these forums will be an easy one...
I just pulled my boat of storage (outdoors) and I popped the cover on my motor for a visual inspection. Unfortunately there's what appears to be mold covering a lot of different parts of the engine, particularly the lines and the electrical connections. The foam lining inside the cover also appears to be harboring some of this mold. What's the easiest/best way to clean this out? I don't know if it is causing any direct problems -- the engine still runs okay -- but I'm assuming it can't be good. I can post pictures if that would make things easier. BTW, the model of my motor is J20CRCOS.
Thanks,
Brett
