Re: 4.3 mercrusier
The thermostat for the 4.3 is a 143? stat, but that is not the normal operating temp.
At idle in gear, there is no load on the engine, and with all that cold water, it may not get up to temp. When you get on plane, you should be seeing around 170? on your temp gauge. Even if you change to a 160? stat, it will still run in the 170? range and will not hurt anything, even at WOT (Wide Open Throttle). The lower temp stat is mostly there incase the engine is used in salt or brackish water. If in fresh water, no problems using the 160? stat.
If it's loading up, you still need to adjust the carb mixture and tune the engine up and make sure the choke is fully open.
