texsun
- Jun 30, 2003
- 156
My 96 Larson 3.0 VolvoPenta is spraying water from a hole that is at the back of the plastic exhaust tube. The tube that leads from the riser to the bottom of the transom. From drawings I have seen I believe this is the hole where one side of the "flapper" mounts/fits. At first I thought it was a hole in the bellows, but by using a mirror this wkend I can clearly see it's on the plastic tube. What causes this leak/spray and how can I repair it?<br /><br />Thanks for the Help!<br /><br />Mark
