Primitive Pete
- Jun 29, 2008
- 31
I am just starting the process of painting a 16 foot aluminium Jon Boat. Here is what I think I know:
1. Degrease and sand with 180 grit sandpaper. Not necessary to remove ALL factory paint as long as all surface is clean and sanded.
2. Prime with NAPA self etching primer OR Galv-Alum primer.
3. Paint with automotive OR marine paint.
4. Clear coat.
Apply 2 coats of primer, paint and clear coat. Can apply with roller but spray for a better finish. Have an old compressor that delivers 6.4 SCFM @ 40 PSI. Have thought of getting a good airless HVLP spraygun in the $150 range that can use unthinned oil based paint.
Questions: What to use for a degreaser and need advice on what primer, paint and clear coat to use. If spraying will produce a much better paint job, what paint gun will work with my compressor, bottom feed or gravity feed? Will an HVLP paint gun work with my compressor? I know there are $50 paint guns out there but are they worth it?
Any thoughts on using an airless paint gun?
4. Clear coat.
