My 94 60hp 2 stroke oil injected motor will not go above 7 mph. (no tachometer)
-Motor revs fine on hose not under load
-I have rebuilt the carbs, fuel pump, replaced all fuel lines, new plugs, wires and a new coil pack.
-120-123 psi in the three cylinders
-Appears to have good spark in all cylinders only by looking at it
-Bottom cylinder/plug will not get hot or look like it has been running but if I flip that carb throttle it will run up rpm on the hose
-When I pulled the bottom plug with engine running while wearing gloves and a towel I got zapped
-Idles fine
-Boat is a 2001 Starcraft Starfire that came with a 2 stroke 25hp fuel mix
-Boat buzzer/alarm under dash is always on with new motor (could be bad oil injection sensor)
-When old school timing light is hooked up to all cylinders they all light up
Any ideas out there before I give it to the local marine dealer and pay out the rear?
Thank you
-Idles fine
Thank you
