Re: 1979 MERCRISER 470 -TILT AND TRIM Motor/17 starcraft tristar
follow the hydraulic lines that come from you transom plate to the pump. under the pump is a plastic tank. That is where you add fluid. ( adding fluid is not normal) you must have a leak that really needs repaired. just run the trim up and down and look for the leak.
