Help! Forgot to put drive in FWD when I removed the lower unit. Then put drive in FWD prior to removing and servicing the upper unit. Having trouble re-installing both now.
1. What is the easiest way to install the upper unit (sans lower unit)?
1a. The darned rubber gasket on gear housing keeps falling off and jamming too.
2. What do I need to do to reinstall the lower unit (once upper unit is installed)?
3. Is it easier to install lower unit to upper while on bench, then install whole unit?
Time to build that OD stand I've been wanting to do for so long. My back is killing me trying to put this back together.
Thanks for any help.
