Just got done cleaning the carbs on my friends 2000 Johnson 50hp motor. after starting it up it would idle fair, if i gave it some gas it would level out. When reving the engine up, about half the time it would rev up really high and I could not cut it off. The only way to cut it off was to pull the gas line off. The key would not cut it off. Now if it is idling normal I can turn it off with the key. 1st off what makes it idle to wide open on its own, (the butterflies on the carbs are even closed) and 2nd why cant I turn it off with the key when this happens. Any help will be greatly appreciated. Was hoping to hit the river tomorrow.
