Re: Switching to a HEI ignition on 4.3L Mercruiser
Yes and no...the timing curves are way different between auto and marine. The marine ignition system will reach full advance at 3000rpm and has a nice gradual advance curve where as a an automotive distributor reaches full advance around 4200 rpm and has a much more agressive curve from 2000-4200rpm. You will probably be able to make it work but you will not be happy with the performance and you will most likely be getting estimation on the top end because an automotive advanc generally will advance to 32? max vs. a marine curve reaching a full advance of 26?. Is your ICM an old or new style the new style is about 1.5x3" the old style is a 4"x4" box. I have a ICM from a 94' 4.3L...new style
