JordanFTW
- Nov 9, 2010
- 17
HELP :redface:
I am trying to remove the rams on my SX drive and I cannot for the life of me get them off. The fronts are loose but the rears are really stuck on there. I have the type that uses a c-clip and washer. I tried prying the hell out of them, and was starting to rig up some straps to try and pull them off but I dont wanna damage anything. I have already really put some force into this! I removed the ground bolts from the back, even though I am not sure that is necessary. Do I need to trim it all the way up just to remove them from them from the housing or something, are they keyed inside or something? I am not planning to disconnect the lines I just need to pull them off the pivot housing.
I searched everywhere and am really having trouble with this. The manual does say to trim it up but that is just to equalize the fluid before removing the lines.
Any help would be GREATLY APPRECIATED!
