1985 Mercruiser 140hp
walte27f
My dad has a 1985 Rinker 180V with a 140HP Mercruiser I/O that has been sitting for 3 years. I am an aircraft mechanic that knows how to bring a motor back from the dead but have no experience with boats and am looking for information to be prepared to start this project before I drive 12 hours to pick it up. Does anyone know what spark plugs are on this motor, oil and filter, battery, carb kit part number? Any information would be helpful, so I can have parts in hand when I pick it up in 2 weeks.
Thanks,
Jarrett
EClass20
Re: 1985 Mercruiser 140hp
I have a 1985, Merc 3.0 140 also.
Plugs: AC Delco MR-43-T Gap: .035
Oil: SAE 30 or 40 (5 quarts)
Oil Filter: NAPA 1086
Timing: 6*BTDC
Idle: 700-800 RPM
I'm using a deep cycle marine battery. Want to say off top of my head 675 cold crank. $75-$80 @ Walmart.
Carb Kit # based on your carb.
Change your fuel pump filter. I don't have a #.
EDIT: Distributor Tune-Up Kit: 34235T-1. Has rotor, points and condenser.
DeWell: .022 gap or 28-34*
This site will have all the part #'s your looking for.
http://www.mercruiserparts.com/selectDocs.asp?doc_nbr=41261
Find yourself a Clymer Mercruiser Shop manual. You will need it. Book # for years 1964-1985 is: Clymer B740
walte27f
Thanks very much for the information, I have ordered everything, including the manual
Don S
That is the worst possible choice anyone could make for a manual. Get the one Bondo linked to above. Not only is it free, it's the OEM manual from Mercruiser with all the information in it, not just selected items like clymers. If you ordered the Clymers, I suppose it will make a good knee pad. Personally I prefer the Seloc for knee pads, they are a bit softer.
Ayuh,.... A few years ago, I made a comment similar to that over Here....
The Publisher of Seloc hangs out there,...
It didn't go so well..... :rolleyes:
