redgoat
- May 23, 2010
- 102
I recently learned that the current motor oils, namely SL and SM, do not contain the bearing protective property zinc plus phosphorus. Without this additive in the motor oil, older car engines could potentially be damaged. I would think my 44 year old Mercruiser 153 cu.in., 120 hp, 4cyl Chevy engine could be at risk. Should I add this zinc additive to my current 30W oil? I found some available on EBAY called ZDDP. If so, how much should I add for an engine with a 3 1/2 quart crankcase capacity? I would think all older boat owners should be alerted about this development in motor oil. I already add a lead substitute to my fuel system since current gasolines no longer contain lead.
