LongueCarabine
- Jun 10, 2011
- 10
Hi everyone:
I'm new here, inherited a 15hp Johnson (1995) from my Dad. Motor was running as of a couple years ago. My sister used it once last year and noted that it died on her when she used it.
I have changed the spark plugs, (it had 2 different plugs, neither was the specified plug) drained the gas and put in a fresh mix, soaked the carburetor in cleaner and have disassembled / reassembled it. Did not see any corrosion or badly gummed up parts, although the old fuel mix did smell like varnish.
Gas is getting into the float bowl, but from what I can tell, is not getting into the engine. At least, that is my assumption since the engine would not catch. I have pumped a little into the cylinders through the spark plug holes, and it will run for a few seconds. It sounds like it is running correctly, so I am stumped as to what could be going on.
Can anyone help?
Thanks,
LC
Can anyone help?
Thanks,
LC
