Re: Acc1 wiring Q
Best bet is to ground the fish finder at your fuse block/bus bar, then with a multimeter/test light find where your switched power is on the switch. It looks like those switches are low power and goto relays elsewhere on your boat. Follow the wires to the relays, and tap into your power there. If there is no relay for accy then you'll have to put one in.....your asking for trouble if you start guessing what wire does what.
Personally I have a few items (low power) hooked directly up to my switches....All my switches are individual though....If you put to much stress on the circuit board you could screw up all your switches.
