I've got a 19ft carolina skiff that has been painted. When the paint was sprayed it was applied directly over the existing gel coat. Is there a method or solvents I can use to remove the paint without damaging the gel coat?
Also, I can see a few areas where the paint was taken off and the gel coat is gone as well in those areas, can you apply gel coating to JUST areas where it has been scratched off?
