So I took the boat with a 1985 Force 125hp outboard out on the lake. First of all it didn't go fast enough to plane. And then after 10 mins of operating, It lost half the speed. It has also been dying at idle speed. I need to keep on the throttle to keep it going.
I performed a compression test with the following results:
Cylinder
#1 - 70 psi
#2 - 60 psi
#3 - 60 psi
#4 - 0 psi
the specs are 145-165psi
The spark plug for no 2 is also noticable different after running...barely wet with fuel
the other 3 are dark and have fuel mixture covering them.
Any ideas where I should start?
Thanks!
Cylinder
#1 - 70 psi
#2 - 60 psi
#3 - 60 psi
#4 - 0 psi
Thanks!
