Ocean Runner Tilt Jerks
dshefferly
When I try to tilt the engine down it bounces and jerks; does anyone have a suggestion?
nwcove
Re: Ocean Runner Tilt Jerks
maybe needs a bit of hydraulic....or whatever kind of fluid it takes? mabe some grease at the pivot point?
boobie
Try loosening up the big nuts on the tilt tube, grease the heck out of the fittings on the tube and then run it up & down.
boobie
One more thing. If this mtr has been in salt water, the upper pin on the tilt ram may be giving you probs too.
