This is a re-post had to sign up with a new login, old one quit working.
This is a pic of the mariner the day I picked it up. I got it for $1800, it came with trailer, 90 hp V4 and 6 hp kicker that looked so new, I did a break in cycle on it when I ran it. Boat hull is in great shape, minus the transom - nghtmare. A lot of galvanic corrosion, that from what I can tell is fairly common on these boats. Last guy puts so much goop in there is caused the transom to bow some. I was able to run it once and topped out well at about 35mph, these boats get on plane quick and hardly throw a wake, As far as I could tell only one rivet leaks, easy fix. I have since ripped out the deck, c.c. and transom. I am starting to put it all back together so I'll send more pics of the transformation shortly
