Re: 58 evinrude lark 35 hp lower unit removal and where does it pee from
Those old motors did not have thru hub exhaust like the newer ones, they also did not have the telltale or peehole.
If you look above the prop there is a tube thing that hangs down like the direction tab on the back side of the cavitation plate. It has a screen in the front of it for a water pickup and the back has a hole that is prolly black that ges out behind the prop if going foward. Some exause comes out here. It will also have 2 holes on the midsection on the rear of the motor, like said before the exhaust releif holes water and exhaust will just dump out these holes as well as the other i mentioned.
Just paid attention to the year this may not be entirely correct. It is for the 60s and 70s vintage that did not have teltales, i have no idea on that old.
