renegade15
- Mar 29, 2009
- 99
So I can not get my 1988 E60tlccr to run more that a couple minutes above about 4k rpms before it just quits, very abrupt. But then starts right back up... It will run at 2-3k rpms no problem, but above there and it dies. I don't want to hurt the thing so I keep trying things in the fuel delivery realm. So far have rebuilt the carbs, cleaned the jets and orifices multiple times by both myself and Dave at Tuck's Marine here in Pinellas Park, FL. Additionally he boiled the carbs since the motor had been sitting before I bought it. I replaced all fuel line from tank to the racor(new filter too), to the pump, to the carbs, replaced fuel pump since the VRO was bypassed anyways, replaced primer bulb. I did a link and sync and timing, then the shop did too after he messed with carbs and installed the fuel pump.
What direction should I go next? I have a call into the shop but I know they are very busy with prime boating season. Dave said he did a good once over on everything else and that it seemed like a really clean motor other than the high rpm cutout. I am going to get a portable this afternoon and try running it off that. It is the single thing the shop did differently. But I had drained the tank after it sat and installed the racor fuel/water seperater to alleviate thos problems. Also the primer bulb does not go flat which seems to happen when there is a restriction from the tank?
Anything I'm missing???
Thanks!
Thanks!
