wi4x4man
- Aug 25, 2010
- 55
Hi,
I am working on putting a 4.3L Mercruiser setup together. The engine is a 1990 (pre-balance shaft / non-vortek) arrangement. There is a terminal block on the shift mechanism that ties into the white/green wire and the black ground wire. The white/green wire of course goes to the distributor.
My question, is how is this supposed to work? What is the operating principle behind it. I am very very familiar with Diesel engines and diesel engine controls for them (I design them), but for the life of me I cannot figure this arrangment out. Why would you want to ground it out when you shift from neutral to forward or reverse? I purchased the boat without an engine, so I never did see how everything was hooked up. Perhaps I am missing something.
