1988 Mercury Black Max 135 HP Lower Unit fit on 1987 Mercury Black max xr4 150hp?
mercury23
1988 Mercury Black Max 135 HP Lower Unit fit on 1987 6v Mercury Black max xr4 150hp?:confused:
j_martin
Re: 1988 Mercury Black Max 135 HP Lower Unit fit on 1987 Mercury Black max xr4 150hp?
If the same driveshaft length, yes. Different prop if the XR4 was original. Original XR4 was 1:1.78 ratio, 4 " prop hub. Standard V6 is 1:1.87 ratio, 4 1/2" prop.
hope it helps
John
mercury23
and how it measures my drivesaft:( ?
j_martin
I think if the engines are the same shaft length, it'll work.
mercury23
hello again. my 135 hp lower unit does not work.:mad:
I am interested in buy a used and good conditions 1987 v6 150hp lower unit mercury XR4:)
j_martin
What didn't work? Any long shaft (20") V6 LU should bolt up, even the old spring loaded ones.
mercury23
hello martin, the unit is like mine, damaged gears :(
that?s why, I want to buy another one, used of course:)
Faztbullet
Go to SEI and get a new one with 3 yr warranty, only $900
mercury23
hope it helps
John
ok well
Hi
if my old case lower unit is 4 " 1.78 , and prop (m turbo 13x4x24)
Below is a picture of my old prop.
what kind of prop I can use for the radio 1.87. for my bass tracker boat 1988 17fl.?
j_martin
If it spun up pretty good, 23". If it was marginal low RPM at WOT, 22".
Likely with a bit more drag with the bigger LU, you'll need a 22.
