Jay Gadsby
- Jun 26, 2010
- 22
Hello ladies and gents. I blew my engine about 8 months ago, been slowly rebuilding since then. I have had the outdrive off a couple times for repairs and engine pull and such. Today I hooked everything back up, the engine is in, all the electronics work etc. I went to trim down and the outdrive would not move. The motor makes noise, has oil (good oil), no kinks in the lines etc. My father-in-law and I decided it was the hydraulic arms for the outdrive not moving. Well, we were correct. I removed them from the transom and brought them into the little garage of horrors that I call home to get them to hopefully move a bit. With some help from a BFH and some wood we were able to get them to move about 1.5". This is with no pressure in the system. Although, every blow forced more oil out a little splatter at a time. These are more than likely the original arms on the boat, but at this point I am at a loss. I do not have a spanner wrench large enough to take off the end cap on the housing itself. Anyone have any ideas? Ever seen this? Any information would be awesome. Thanks in advance!!
