  #1
Old March 14th, 2005, 02:41 PM
Homerr Homerr is offline
Default When do you replace your anodes? Zinc or Aluminum?
When is a good time to replace your anodes?I don't think mine need them yet, but I was wondering when the rest of you do.My book says 'when they are about half worn' ... problem is.. what do they mean by half?I can't find a 'dummies guide to replacing anodes' Anyone have some pictures of going bad/very bad anodes?And lastly, should I stick with the zinc anodes or go with aluminum?Thanks,H.
  #2
Old March 14th, 2005, 04:12 PM
lenny2113 lenny2113 is offline
Default Re: When do you replace your anodes? Zinc or Aluminum?
I replace zinc anodes every season. I figure it is better to invest in zink anodes then into a new outdrive. I would say go with zink anodes. I have not used aluminum anodes as I think it makes no sence, since your drives are aluminum casting. "Sacraficial anode" serves the purpose of sacrafising itself to the electrical currant that is common to boat docking areas where shore power is almost on all boats. I would change every season only because I keep boat in the water for the season. If you trailer your boat I would say replace it when you see zink starts falling apart.
  #3
Old March 14th, 2005, 04:26 PM
trog100 trog100 is offline
i think the "dummies guide would say replace em when they are half gone.. and keep the crud off em too so as they can do their job..i also read somewhere that if u have a little aluminum boat.. all linked up shore-power wise and moored next to some big steel hulled boats for example.. your little boat becomes the sacrificial anode for the whole bunch of em.. he he trog100
  #4
Old March 14th, 2005, 05:01 PM
Dunaruna's Avatar
Dunaruna Dunaruna is offline
Send a message via Skype™ to Dunaruna
A sacrificial anode can be made of any number of alloys and alloy compositions, the word 'zinc' is a commonly used generic term term for all anodes, it doesn't always mean that they are made of zinc.Use whatever the leg manufacturer recommends, that can change depending on 'warm or cold water', 'salt or fresh' and 'alloy hull or glass'. Stainless steel props can affect your choice also.For example, magnesium anodes are common for the type of hull I have and the area I boat in.Half worn is a rough guide, the smaller they get, the less surface area to sacrifice. Keeping them clean also increases the sacrificial area.Aldo.
__________________
Watch this space......................
  #5
Old March 15th, 2005, 04:21 AM
TilliamWe TilliamWe is offline
the ones that mercruiser recommends for "freshwater use only" are magnesium. Not sure what the "standard" anodes are made of.I too have not figured out what "half gone" means, but I do know that you need to clean them off periodically so that growth doesn't decrease their ability to function.
  #6
Old March 15th, 2005, 05:17 AM
lakelivin lakelivin is offline
Homer: out of curiosity, salt or fresh water (can't get a hint from your location "GETTIN' JIGGY WITH IT !!!"), trailored or docked, age of your boat?
  #7
Old March 15th, 2005, 06:16 AM
the other things of course is whatever metal u are useing as an anode it does have to be making good electrical contact with what its attached to and the boats general earthing system..trog100
  #8
Old March 16th, 2005, 06:49 PM
jlcjtc jlcjtc is offline
bought a 1987 renken i/0 2nd hand do ya think i need to change mine?
  #9
Old March 16th, 2005, 06:58 PM
Dunaruna's Avatar
Quote:
Originally posted by jlcjtc: bought a 1987 renken i/0 2nd hand do ya think i need to change mine?
It depends on their condition, if they are fairly new then the answer to your question would be no.If you are not sure then the answer is yes. Better safe than sorry.'Half worn' is just a rough guide, don't get to worried about trying to measure them so that you replace them exactly at the point when they are half worn. Aldo
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
zinc anodes and primer question 2cycle Boat Restoration and Building 6 March 16th, 2007 09:50 PM
Where to put zinc anodes? Muddlerman Johnson & Evinrude Outboards 3 April 11th, 2006 03:07 PM
Anodes -magnesium?Aluminum? Zinc? summerwind1991 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 March 6th, 2006 06:28 AM
Zinc Anodes K7STW Honda & Tohatsu/Nissan Outboards 2 April 7th, 2005 12:13 PM
zinc anodes Dave512 Non-Repair Outboard Discussions 2 June 24th, 2004 03:57 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
