Accidentally overheated engine pretty bad, supply hose came off. Same day wife was practicing backing in to dock and slammed into the back. Now engine seems to chug at low speed but sounds ok at higher speed. RPM to maintain approx 24mph also seems approx 1000 rpm higher than it should be now. If I bring down RPM, boat wants to drop off plain. Pulled out and checked prop and it is OK. Any ideas?
1996 ChrisCraft Crowne 250. 5.8 FL DP outdrive.
