Hi, I have a 2002 Larson 21 ft bowrdider with an outboard setup and 20" transom. The boat is new to me and after mounting a Merc XR2 V-6, I noticed that when the boat is sitting in the water, the drain holes in the splashwell are 1-2" under the water, allowing a puddle of water to collect in the splashwell until under way. There are no issues of anything being waterlogged as the boat is bone dry and doesn't take on water.
The boat is fairly heavy, but is this normal for the rear of the boat to sit this low in the water? The top of the transom is only 4-5" from the water I would say.
The only variable weight factor is that the fuel tank is located in the rear along the center line and holds 35 gallons.
Just wanted to make sure the drain holes submerged at idle is normal?
Thanks!
Thanks!
