i dont agree, 1 carb may be giving you troubles but they all go through the same abuse taking the same gas and ect.. chances are if the other 2 were done at the same time then they may not be just "As" bad but are pretty close and you'll just have another problem next month.If it's just that one bad float needle then replace it and be done, save your rebuild kits for late.
