Evinrude Boater
- Jul 6, 2004
- 1,143
Recently purchased this engine after having saw it run. It was difficult to start and didn't run again after it stalled. I cleaned the fuel system since this engine has been in storage for a few years. Using light-up spark testers I verified last night that there was spark but tonight there's nothing. Used an adjustable gap spark tester as well. Are there any safety switches that might prevent it from starting such as a neutral safety? I unplugged the kill switch wires. Should there be continuity between those two wires when the switch is disconnected or is that normal?
It's getting fresh fuel, it's in the test barrel water.
Spark plugs cleaned and gapped
Compression is about 60 psi
