I have a 35EL76S that I have done the following work on: carbs, impeller, coils, points,condensers, thermostat. It was just starting to run well, while checking the points and cranking it over to check for spark I noticed a significant amount of water misting out of the top plug.
I checked the forums for info and inspected the head gasket and exhaust gaskets. Neither had tell tale signs of leakage. I ended up making new gaskets for the exhaust cover that turned out great. Slapped it all together and I'm still getting water in the top cylinder. The exhaust port is absolutley coated in it. This did seem to happen shortly after I intalled a thermostat. There was not one installed previously.
I have 120 PSI in both cylinders. Besides these two places is there any other spot I should be checking? Everytime I take something apart on this beast something else breaks. I've just about had enough!
Any help would be appreciated. Thanks in advance.
Luc
Luc
