IRON DUKE 3.7 Liter 190 hp Fuel Consumption
mnorton227
I just bought a 1985 Four Winns Santara with a 190 hp 3.7 liter (224 Cu. In) merc outdrive. I was impressed with the power of the motor in a 3000 lb boat. I was told that this is the "Iron Duke" motor, but have seen a number of posts that say that the 3.0 liter is the "Iron Duke".
Does any body know which is which?
Any Info on reliability?
How about Fuel Consumption at 4000 rpms in gallons per hour?
Would love to here your feedback.
Thanks
superbenk
Re: IRON DUKE 3.7 Liter 190 hp Fuel Consumption
I've seen the name "Iron Duke" thrown around a lot for the GM 3.0L, but I'm not sure that's 100% accurate. If anything I'd expect the similarities end at the block. I'm sure someone with more history knowledge can chime in with better info.
As for fuel consumption, my 3.0L gets ~3-4 MPG at 4000 RPM (very rough estimate). At 25MPH, that's 6-8 GPH (again, very roughly).
Don S
It's definitely not the "Iron Duke", since it has an aluminum block Designed by Mercruiser, and a Ford 460 head.
GM had the iron duke, not even sure it was the Merc 2.5, but it sure wasn't 3.0L either.
TilliamWe
Banned
I just bought a 1985 Four Winns Santara with a 190 hp 3.7 liter (224 Cu. In) merc outdrive. ...
I am sorry to hear that.
Reliability is BAD if you don't know how to maintain it. And even then, it's spotty.
As the link shows, the Iron Duke is a Pontiac 151 Cu In engine. What you have is most definatley not iron, nor a Duke! hehehe
RogersJetboat454
Aluminum Deuce is more like it.... :D
Pretty sure the Merc 2.5 was a variant of the 3.0L. The "Iron Duke" known as the "Tech 4" or cross-flow was mainly a transversely mounted engine, although they did stuff them in S-10 trucks/blazers, Camaros, and Grumman LLV postal trucks. You could time there 0-60 in minutes instead of seconds....
