Re: 1991 Evinrude 50
With the engine running the primer bulb will not be hard, it will soften up as apposed to being firm when pumping up before starting. You should start with some basic checks, compression, spark and fuel delivery. Is the fuel fresh, any visable fuel leaks in the lines?
