Hi, I recently bought a 1978 evinrude 115899c 115hp outboard. The tilt/trim has been giving me some problems, here is a description of what happens.
-Trim up works smooth and fine.
-Trim down works BUT when i have the switch pressed the motor spins but does not lower the engine until i let off the switch.
-Tilt up does not work (stops when tilt is at max and requires manual lifting to tilt engine all the way up (drops a little bit once switch is released)
-Tilt down works fine until I get to the top of the trim (then it operates as described above)
Things done so far:
-cleaned electrical connections inside tilt/trim control box
-tried bleeding ATF (up and down a dozen times but there always still seems to be a bit of air left in the reservoir when i unscrew the filler to top up)
All of this I have been testing on the trailer. Is is possible that the motor is not getting enough juice to tilt up? Or more likely that I'm failing to bleed all the air OR have some other hydraulic problem? Any input will be greatly appreciated. Thanks
Things done so far:
