Hi all and thanks in advance for any help. I have a 24' raven pontoon with a 1989 75 hp mercury 2 stroke 3 cylinder with cavitation/ventilation problems. I do not have much history on this boat as I am restoring. At present it has an 11 pitch prop(48 77338 a40 14") The motor runs fine and with 2 people on board it tacks to approx 5800rpm. There is a on and off prop slippage throught acceleration. The slower the acceleration the less prop slip. Hard right hand turns are a sure way to get the slippage. I do not have a speedo but I am not real concerned with speed. With the motor trimmed all the way down give best results but boat bow seems to plow. With positive trim to raise the bow more slippage is produced. I marked the hub and prop and went o wot. the marks were perfectly in line upon return. The motor does have 1 more hole that I can lower on the transom. Where do I starts? Thanks in advance for your help.
