Hi Folks,
This one seems to have my mechanic baffled, so I would appreciate any possible assistance. I have a Mercruiser MC 898R in a 1984 Searay. This season she has the annoying habit of starting up, going about 1/2 or 2 hours just fine on plane, and then I bring her down to slow or idle and after a few minutes the engine quits and won't restart. First, the mechanic replaced the ignition sensor. The next time it happened, he replaced the the ignition coil which he said was cracked. It happened again. Now he's scratching his head. He thinks that there is a short somewhere causing the failures and he thinks all of the wiring harness shoule be replaced. That would cost more than the boat is worth- not going to do it. I was wondering if any of you might have some ideas and would greatly appreciate some suggestions
