There is no real "testing" for a carb. during the cleaning process blow compressed air through every orifice you can and see if you can feel it come out some where in the throat of the carb. (those little holes by and behind the throttle plate. Blow through the fuel inlet and make sure fuel can get to the float bowl. Now that being said can you give us some more details. Have you checked spark and compression? If after trying to start the motor you take out the plugs, are they wet or dry? Have you checked to see if you have fuel to the carb? Could there be a fuel supply line issue?
The plugs are basically dry. I can pull it a few times an remove a plug, put a match up to it and it poofs. So i think it is getting gas. The recoil pull is is not working well. I have spark on both plugs when i pull and hold them to metal. Also if i put my finger over the spark pull hole, it will suck it in when pulled.
