Help! need 1985 mercury 120Hp I/O wiring diagram
85Cimmaron
Need 1985 mercury 120HP I/O wiring diagram to troubleshoot. Won't start for the first time. Thanks!!
Bt Doctur
Re: Help! need 1985 mercury 120Hp I/O wiring diagram
What does that mean exactly. "wont start"
turn over
actually run
does nothing, not even click
battery dead
no power to coil
man overboard switch activated
shift interlock activated
85Cimmaron
Well, the motor will turn over, there's power to the coil, and the carb has gas. New spark plugs, distributor cap, points and rotor last spring fixed the same issue, don't want to replace all that again this year. any thoughts? Thanks!
