I have a 1982 50 hp Johnson that I took out yesterday. It started up fine all day until I shut it off at the ramp to get the truck then I couldn't get it turn over. Checked wiring and connections everything was tight. The electric choke would engage but when I turned the key nothing. I was woandering if the key itself can go bad? I haven't had time to use a tester on it to see if I'm getting power to the switch because I got in late last night and working today. Just figured I'd ask real quick and get a few opinions from here. Also I checked the fuse, it was good and I replaced the starter solenoid last week. Where can I find this item? Thanks
