After turning the battery switch on (checked - strong battery), placing the gear shift lever in neutral, attaching lock plate to the engine stop switch, inserting the key and turning it to "on", I get nothing. The digital gauges are not powered. Other eletrically powered devices on the boat work with the exception of the trim located on the gear shift lever. Any troubleshooting ideas? Can I bypass and start the engine?
Trey B
Trey B
