was running the water hose on my engine today and noticed water running down the outside of the engine midsection coming from under the engine cover. Took the engine cover off and found a spray of water from the bottom of the engine where the tube attaches for the pee tube. Tried to tighten the bolts thinking they may be loose but already very tight. Is this going to be a simple fix or could this be a more serious problem. thanks
