Here's the scoop -
A friend picked up a 60/70's runabout, with a 35hp Chrysler. It wanted to spin the prop all the time, even though it IS a F-N-R model. it was just really tight. Got it to run, and it runs great. but it's always turning..
Pulled the lower off, and it was rusted to hell, with water as lube. Needs new bearings, which i'll order from the local bearing supply house. It also needs new seals, (p/o had used JB weld to seal the two lowers together....WTF is wrong with people?!) and gaskets. Everything LOOKS fine, but I can't see the cause of the constant drive issue, AND, I need to find a place that can decode the engine S# to get me the year, as the P/O felt it was a '71, and ordered (from iBoats!!!) a re-seal kit that IS NOT for this motor!
I need the correct year to supply iBoats with the right info to order the parts....These old Boats are way more fun, and addicting than my Sea Ray!
ON the Outboard Tag - 35HP Model 35602, Serial # 1116 Chrysler Barrie ON
Cliff notes - Why's I gots no neutral
- Whut year is dis motor?
