Re: Oil leeking out of Bottom Weep Hole (Evinrude 33)
I was thinking the same thing with my 33 Ski-Twin.
The engine sat for fifteen years before I got it, on a stand in a garage near Toledo. I brought it home squirted penetrating oil in the cylinders routinely. Good thing I inspected the lower unit. If I were to drain and fill it and run it it would of destroyed itself. The gear lube looked ok, yet taking the unit apart revealed rust stuff stuck to the hard parts and cast parts like sticky goo. Yet every bit of it came off in the parts cleaning tank. I was careful not to disturb the shift rod seal. I wet sanded it above the operating zone of the o-ring to remove crud so I could pull the shift rod through cleanly.
First time out I had it adjusted too rich. And all the spray stuff I put in the cylinders during the winter, came oozing out of the weep hole. So I thought there was something wrong with the lower unit, like if it were leaking? I unscrewed the drain screw and let just a bit of gear lube drip into a plate after sitting overnight, no water whatsoever, perfectly looking gear lube. By the way, the weep hole was plugged up when I got the outboard. That may be why there was rust goo in the lower unit when I got the outboard, maybe water seeped in through the shift rod seal. As the water level had risen in the pipe part there due to the weep hole being plugged up.
Next time out I leaned it out and the exhaust got good and warm, plugs look a bit warm too. Thinking I'll go to a J6C plug, even though the Champion book says J8C. Anyway only a little bit of goo is coming out of the weep hole which I am considering normal.
I'm going to stick to this 65 33 Ski-Twin for a while. I don't need any more of these new old outboard jitters,,,, shew.....
By the way the prop was extensively corroded, like it had sat in water yet never used. I ran it through the electrolysis tank and it is pitted as hell, yet looks never used besides that.
It never hurts to double check things, you could forget something once.
Steady as she goes....
