scott2000d
- Jul 3, 2008
- 31
I have a 1986 Johnson GT150 J150STLCDC that has been giving me troubles since last summer. My brother was using it and hit a wave very hard and stopped the boat dead. The boat shut off when he hit the wave. Afterwards it started right back up and ran fine. He stopped shortly after and shut the engine down. Everything was running fine up to this point. This is where it all went downhill. When he hit the starter it just made an odd whirring sound like the bendix gear wasn't engaging, so he went back to take the cover off the engine. When he got the cover off he saw that the nut, washer, and spring had all flown off the starter. Next smoke started rolling out from under the flywheel on the back side of the engine. In the area of the regulator/rectifier from what i can gather from his description. He had left the key in the on position, he turned the key off and dumped water on top of the engine to stop the smoke. :facepalm: After that the engine started up using a rope, and he drove it back to shore and loaded it back onto the trailer. But now found the trim wouldn't work.
When he brought the boat back to me there were many loose screws all around the boat, that's how hard he hit this wave. The trim was not working because of a blown fuse, but whenever I replaced it the fuse would blow as soon as I plugged in the big red wiring connecter. With the connector unplugged the fuse would not blow and the trim worked fine. I completely disconnected the stator, and regulator/rectifier from everything but the fuse just kept blowing. I worked on it for countless hours at the end of the season last year before I finally gave up for the winter and went snowmobiling.
When I got back to work on it this spring somehow the fuse has stopped blowing and the trim works fine. I reassembled everything and it started right up and the trim works great. However when it is cold it sometimes seems to only run on the right 3 cylinders until the engine warms up and then it has full power again, although while running it sometimes hesitates and momentairily goes back to 3 cylinders, but comes out of it before the boat even comes down off plane and takes off again. I have had it out 5 times hoping that the not running on all cylinders problem was from stale gas and now I've run a full tank of supreme through both tanks so I don't think it's a fuel issue. I got it out today to try testing if the port side cylinders are getting fire but it has been running perfectly all day. Go figure. Aside from the not running on all cylinders all the time the tach is not working.
With the engine running at idle I read 12.9V across the battery, I connected the grey wire that runs to the tach to the yellow/grey wire and the tach works properly, I measured the resistance between the brown and brown/yellow wires and i get around 1035 ohm on each side, when measuring resistance between the white and blue/purple/green wires i get around 13 ohm for all 3 readings on both sides. I am trying to narrow down if this could be a bad stator, regulator/rectifier, or both.
Any help on this issue would be greatly appreciated.
Thanks in advance, Scott
