Base pressure.
2011195BR
I got a Mercruiser 4.3 MPI and at 4,200 RPM plus I start getting water in the base and pushes out the dipstick tube. Below 4,000 RPM everything seems to be fine. I was wondering if anyone got any suggestions. I found a hose that comes from the thermostat housing and goes to the bottom of the exhaust manifold plugged with rust and flakes of rust as well. I cleaned that out and it is still the same. I hope that there is someone who can point me in the right direction.:confused:
JB
Re: Base pressure.
The right direction is to the Mercruiser forum. Your engine is not an outboard.
I will move this for you.
Re: Base pressure.
Ayuh,... Welcome Aboard,....
My guess is that, that rust, 'n crud also prevented proper winterization last fall too...
The water froze, 'n cracked the block...
