Did mine (same engine) about a month ago and went really smoothly. Remove all belts by loosening tension bolts and then the 4 for the pump. No harder than changing oil/filter! Loosen the pulley bolts while the belts are still on and it might be a little easier for you, but that's the only tip I can think of.
