Fuel Pick-up
Tahorover
Re: Fuel Pick-up
1/4" NPT better known as national pipe thread
detrlions10
Re: Fuel Pick-up
Thats what I thought, but that seems to be the size of the threads going into the valve. I bought a 1/4 NPT, and threaded it through, but it seems too small. The nylon tubing is too large to even fit down the tank, I had to turn it to thread it in. Has anyone here ever put one of these in? Was it difficult to get the nylon tube down into the tank?
soggy_feet
Re: Fuel Pick-up
You're not making much sense to me...
You bought a 1/4NPT fitting, and a 1/4NPT tap... but your tapped hole is too small for the nylon tubing attached to your 1/4npt fitting?
Are you tapping a new hole, or 'chasing' the threads of the original hole? How thick is the material you're tapping into on the tank?
If this is a new hole, you should be using a 7/16ths drill. Test fit the fitting as you're tapping. Make sure it screws in more than just a couple turns. Youve got a bunch of threads on the fitting, might as well use them.
detrlions10
Re: Fuel Pick-up
Yes, I am "chasing" the threads of the original hole. The last fitting that was in there got broken off flush with the tank. I had to use an easy out to get it out. Because it is aluminum, some of the previous threads were "smashed" into the old ones when using the easy out. I agree, something does not seem right here.
The tap that I bought came with the 7/16th drill. It goes through with no issues. That make that tube pretty thick if you look at the link. Maybe I should just force it in??
detrlions10
Re: Fuel Pick-up
Here are some picks of the hole after I have tapped it. You call see that the original threads are wider that what was tapped...
detrlions10
Re: Fuel Pick-up
Any suggestions on the tap size? It has to be larger than the 1/4 NPT. I really want to get this done today. I tried called the tank manufacturer, but they are out of business.
Don S
Re: Fuel Pick-up
Depends on what you have, 3/8" or 1/2" NPT is the most common sizes of pickups. Measure your threads.
detrlions10
Re: Fuel Pick-up
Should I measure staright across with a tape measure? Thanks for the response.
soggy_feet
Re: Fuel Pick-up
Excellent.
its hard to measure NPT, 1/4 isn't really 1/4 in any way, and its tapered, so the bottom of your hole is smaller than the top anyway. Fortunately, like you found, there aren't that many options that it could be.
Hope you're on the water soon now!
