Re: Help my motor runs like crap
You need to start at the top; Compression test, then spark test, then fuel system test. No sense in jumping around, because you can replace 15 things and scrape every knuckle you have trying to guess. Only 3 things it needs to run; compression, spark & fuel. Once you get these done, post your results and you'll get the answers you need.
