i had the head resurfaced & installed with new gasket -#3 cly is 6lbs low from the #1 & 2- before i disassembled it. Still had the water issue.
I dont have a clue what to do, you think i should reassemble with new seals and gaskets and pray that it goes away?:facepalm:
I replaced all gaskets and seals for the powerhwed and exhaust manifold.
No water, tested for 2 hours cruising and on the flats looking for reds, no water.
Dont know where it was coming from, total reseal worked.![]()
