needwarmth
- Jul 2, 2009
- 7
I have a 1970 60hp Johnson outboard. When it starts, it starts in forward. It should start in neutral. I also do not have reverse. I am assuming this is a "shift solenoid" issue, but not sure. Also not sure where (or if) in the lower unit this would be located. Could this be another issue that's easier to deal with.
Short backstory...the outboard functioned fine a year ago although it did run rough due to dirty carbs. Eventually it quit due to a blown main fuse. Fuse and causal issue was resolved - or so I thought. Not sure if this is related. Any help would be appreciated...
