180 Mercruiser heat exchanger
chrismartin
If never planing on running my boat in salt water, I can I bypass the heat exchangers (twins)?
Fordiesel69
Re: 180 Mercruiser heat exchanger
As long as you do not have the 470 variant engine. Meaning aluminum block w/ cast iron head. If you have this engine then no you cannot bypass. Any other engine yes.
Don S
Nope, your engine is the 3.7 (470 style) engine. 4 cylinder with a 4bbl carb.
It MUST remain a close cooled system.
chrismartin
Thanks for the info. Bummer for me though, both exchangers froze $3,000.00 problem including labor.
Lyle29464
I would rig up a pressure test to check the rest of the engine before i spent money
disregard if you had antifreeze in the closed side. I have seen the 4 inch cooler used for $50.00
stonyloam
Seems kind of high. You can buy brand new exchangers for about $400 each. If they froze it may have only pushed the end caps loose, easy and cheap fix (about $30 for each cap). Any competent mechanic should be able to change them out in a couple of hours. As long as you can get to them and do not have to pull the engines.
Don S
Take you HE's to your local radiator repair shop. Some fix heat exchangers from boats with no problems. It's just copper and solder.
