Re: Expert advise, what to look out for on 88 90hp Chrysler outboard
If it is a Chrysler, then it is not an 88. Chrysler sold to AMF in late 84 and the engines became Force. If it is a Chrysler 90, it can be either a three cylinder or a 4 cylinder engine depending upon the year. The four cylinder delivers a true 90 at the prop and is superior to the three cylinder 90.
If the engine has goos spark on all cylinders and good compression, there is not much else to look for. Oh, you should automatically change the water poump impeller, fuel pump diaphragm, and lower unit oil, but that's about it.
